- 4 Jan 2004
- ¯\_(ツ)_/¯
I'm finally getting to grips with Win7, some things seem a little to XP but I think I've figured out most of it.
Anyway, I'm running Win7 on my netbook instead of XP now, and while it's nicer in many ways, it's not quite as fast as my slimmed down XP install which had some services disabled also.
Is there a guide or list of things I can do to improve the speed of Win7 on a low spec machine? So far all I've done is disable system restore, but there must be some tweaks I can do in order to improve performance?
I don't really use my netbook for much apart from browsing the web and the odd game, so I'm not worried if I cannot run Adobe Premiere on it for example...
