Stripping Exif data from CS2 ?
18 Oct 2005
Kendal
Hi all,
Can anyone tell me how I strip the exif data from raw files in CS2 ? i am wanting to play with HDR and need to produce some tifs without exif.
Cheers
Shorty
Why do you need them without the EXIF data? I've never had to strip EXIF data out of an image to do anything with it.
Save for web should strip the EXIF for you.
I was following the guide from http://petemc.net/hdr-guide/#tools
It says
Load your photo into the editor, then set the exposure level to -2 and save the image as a 16bit TIFF without any metadata such as EXIF info. This is the important part. If you save it with EXIF info you will find that Photomatix relies on that info to produce the HDR shot. The problem with this is that the shutter speed and aperture values will be the same across the 3 images and Photomatix won’t know which image is -2, 0 and +2. Set the exposure level to 0, save that and then set it to +2 and save that image.
Totally new to this HDR business so just floowing the guide like the noob I am :)
