stripping loop down
5 Sep 2008
Karazhan
got one off the rads off cpu block off . so far flushing the rads out with car battery top up well holding and shaking it then pour out , erm just wondering do people re use the tubing ? or better to use new may need to order some if so .
thanks ,
raggs .
yeah i found a big length of the stuff ordered way too much last year so decided to use it up, but no need really no staining at all or cloudiness used that xspc stuff and there blue uv coolant works well. stripped it all down to check for corrosion and nasty algae but nothing found.
use new unless you have a good NONE plasticising tubing.
All tubing dose/will breakdown overtime. and lets face it for £5er it just better to fit new.
