Calling all ROG Strix Z270i (Mini-ITX) users.
I recently bought a Cryorig H7 but the row of MOSFETs (components) on the back of this board stop the backplate from being mounted correctly. I am currently using some nylon washers instead of the backplate but I'm not sure this is suitable (is the backplate really required to stop warping or is it just a mounting mechanism?)
So... What CPU cooler are you using with this board? Does the backplate conflict with the components? I really don't want to get another cooler only to find I have the same problem.
Thanks,
Thomas
Thanks,
Thomas
