Hi Folks,
I am completely new to anythin that is small form factor so please gentle.
Basically the Father in law has just called in and left me with a new SFF case which i am really excited about, he picked it up at a car boot sale for £6.00
So now i have a new project on the horizon, and i can imagine that im going to be needing a fair bit of help/advice with it.
Please see the Images below.....
Dimensions and some Specs
Power Supply
AC adaptor input 110~240V, 50~60Hz universal
Dimensions(mm)
262 x 162 x 310mm
Case material
Aluminum
What i want to do....
Basically i want to make this into a little media centre PC for the wife, i do have some bits and pieces lying around such as the following motherboard ASROCK 775VM800 http://www.asrock.com/mb/overview.asp?Model=775VM800&s= , Pentium 4 630 CPU, 1Gb RAM.
Now what im going to need to do is get a new PSU and make a custom enclosure for it (Due to their being no room in the case, and also i am going to do a fair bit of cutting and grinding to fit adequate cooling for case fans etc.
The graphics card could prove to be problematic....low profile AGP possibly?
Your thoughts/input into this build and if you think its worth bothering with would be much appreciated.
Power Supply
Dimensions(mm)
262 x 162 x 310mm
Case material
Aluminum
