Strong good quality camera case needed
25 Apr 2007
Hello,
I have ordered my new camera and its dimensions are 102 x 69 x 27mm. I now need a good case for it as the main uses are taking pictures while out mountain biking so it does end up with me on the floor occasionally. so could anyone recomend a good quality impact absorbing and strong case.
Cheers
Simon
Check out Peli cases, I've got one of the small ones myself (bought it for taking the DSLR out on a raft), they're bulky but if you want a case they're probably the best. The 'pluck' foam means you'll get a tight fit for your camera.
edit: glossed over the dimensions, this is a compact camera? Peli do do cases for compacts, but I've no experience of those.
Dont know what your looking for but I have a Lowe Pro Flipside 300 which has a good level of padding and a hard shell on the outside.
