I swapped out the power steering and alternator belts while attempting to do a cambelt change (the remainder of which was aborted when I got beaten by a couple of bolts
) a few weeks ago.
Since then my car has had a distinct rubber smell under the bonnet after a drive. Not a burning rubber smell more of a sex shop warehouse sort of smell... I'd imagine
Anyway, I've checked the tension using the vague rules of thumb that I've found on the internet and all seems well in that regard. The belts don't slip at all and after over 600 miles there are no signs of dusting, glazing or any other tell tale signs of poorly fitted or slipping belts. As you would expect the belts still look like new.
I've had a good sniff and I'm certain the smell is coming from the belts.
The only difference I can see is that one of the old belts had a definite taper in its profile where as these are completely square edged.
The last paragraph may well answer my question but the belts were supplied from an MX5 specific supplier and were sporting the correct labels.
Does anyone have any ideas or is it just "one of those things"?
TIA
) a few weeks ago.Since then my car has had a distinct rubber smell under the bonnet after a drive. Not a burning rubber smell more of a sex shop warehouse sort of smell... I'd imagine
TIA
