In the past i could max out my connection speed on wifi even at distance through double layer brick layers yet now after recabling its crawled down to a snails pace.
the recabling was due to me getting a new printer which had fax facilities so i had to unplug all the stuff because the phone line came from behind the printer so i could set up the fax and now after recabling exactly the same way my wifi connection speed is gone, fortunately, i only use my wifi for my 3ds and sometimes my laptop, no gaming just browsing.
Should i try some new ethernet cables since the ones i am using seem to have worn out contacts or is the router dead
