Spie said:Define strength.
Diamond is the hardest.
Grrrrr said:Spider silk is up there along with carbon nanotubes. I'll have a quick google
Royality said:No, I think its a myth... I'm sure steel has a higher tensile strengh. Nanotubing is what google said.
Nope, a hammer will do the trickNeon said:can you only damage/break a diamond with another diamond?![]()
Inquisitor said:Nope, a hammer will do the trick![]()
