Strongest plasterboard fixing?
Caporegime
13 May 2003
Warwickshire
Hi all
I need to hang 4 x floating shelves on a stud wall in a room. There is no way to fix into a stud (without destroying the wall) because of the width of the shelf bracket vs. the width of the studs.
They will mainly have books on them, so a reasonable load.
I've looked at fixing review videos on YouTube and it seems that the two best are Bullfix and Geefix. Does anyone have any experience of heavy-duty plasterboard fixings? Or are these overkill for books and I can get away with some Fischer DuoPowers?
I've not had single fischer wallplug fail in a plasterboard wall, whether it was a duopower, 6mm LDF or 10mm HDF fixing on a variety of applications, heavy mirrors, shelves etc.
I did fix a 24" TV to a plasterboard wall once but opted to use some gripit fixings, which also worked well but likely overkill for your use case.
Floating shelf direct onto plasterboard won't end well. The thickness of the shelf is small, so they'll be a lot of twisting force rather than shear down force. You might get away with it for ornaments, but not books.
I’d be tempted to use Corefix if the shelf will carry a reasonable load, at least that puts the weight into the wall behind which feels safer for something like a shelf with more of a lever arm. The other plasterboard fixings are very good with shear force but I’d still worry about them pulling out of the wall over time with a heavy shelf.
Just watched and when I last researched this years ago (10, as I needed to refix a radiator that had pulled off the wall when we bought our ex rented house) the GripIts were the best.
I'd never expect them to hold 90kg, but how do they rate them at 90kg when they only do a third?! Is there an asterix on the pack that says "plasterboard reinforced with steel required." :eek:
Loads of options. I use Geefix, grip it blues and spring toggles depending on wall construction (cavity size). All have been fine. All hold TVs up on plasterboard walls.
Really struggling to see how you can't hit at least one stud? Unless the bookshelf is less than the width of your stud spacing and there is a very specific spot you want it to be which is in between the studs. Surely you can get at least one of the brackets to hit a stud? I'd feel much happier if one of the brackets at least was in a stud and then you can put the others into plasterboard.
Is it an internal partition wall? Or is it lining a masonry wall? If it's lining a masonry wall corefix are great.
Don't forget, if it's an external wall (plasterboard --> cavity --> external brick) then you can just drill straight through the cavity and into the external brick.
Get a long screw, loosely put a red plug on it, then tap it back to the hole in the brick.
Gripits are fantastic, as long as they’re not used for an item such as a Dyson wall mount.
If found over time they have pulled through the board.
Hollow wall fixings
I've been using them for a while now and they so bang on, even tried on lath & plaster with success.
Thanks but it's one of the few walls in my house that is plasterboard to void to more plasterboard.
It's a 600mm wide alcove (same as the floating shelves) and the studs are at ~500mm, whereas the shelf brackets are 400mm wide.
Hollow wall fixings
These are the bees knees, used them for years - we use hilti ones at work which are a fortune. You should always use the tool though, you can get away with screwing it in but it spins the hole causing the little teeth to spin and chew up the plasterboard whereas the tool pushes it in to grip it.
Corefix for this type of thing, then the load is on the metal sleeve rather than the plasterboard itself
Why not just do one side of the fixing into the stud and then use either a hollow wall anchor as linked above or use the fischer things and you’ll at least know you’re solid on side. Use a decent sized screw into the stud and it’ll never move.
It's not possible to mount into the stud and fix a 600mm floating shelf because the mounting bracket is narrower than the shelf and the alcove is 600mm wide.
Perhaps if I post a pic of the area and the shelf...
