- 9 Dec 2009
- Bristol
Hi all
Here's a sketch the garage roof:
There's a large loftspace which I'm going to utilise, but the 4x3 joists are widely spaced and because they run the length of the garage they're not continuous, they consist of 2 pieces of wood joined with what I understand is called a biscuit joint. I'm going to strengthen the roof so I can stow stuff up there and also scuttle around up there getting stuff down and organising.
The plan is to double up the existing joists and have a large supporting timber across the middle. I've indicated where the new timbers will sit using dotted lines in the sketch. I've measured up but have few questions I wonder someone can help with.
Firstly, what is the correct method to attach the central timber to the blockwork (concrete) either side? There is a blockwork pier on one side I could build up a couple of courses and use as a bearing but the other side (which is the gable end of our house) is a clean blockwork wall. I've researched this and everything points to using something called a multi truss hanger, but the central timber isn't just a joist, it's the central supporting timber. What can I bolt to the wall as a support?
Secondly, what size should the central timber be. I was hoping to get away with a 6x4, will this be adequate?
Lastly, what is the correct fixing for "sistering" the new joists to the old? Long screws? Nuts and bolts?
Thanks for reading, any comments welcome.
