- 12 Feb 2006
- Surrey
i got a nice new 24" monitor arrving thursday and i plan on using it at nights as a tv which will be used for watching dvds/, playing the wii and watching normal 1-5 channels and viring box (thought the box is not in my room i just get whaty every channel it is currently showing).
i know that i need an external tv tuner for this but i am really sturggling to find one that is perfect for what i am after, main problem being that most require the pc to be on to use where as i want one that just plugs straight into the tft.
also i am trying to get one that will look good on a 24", where as all the ones i am finding seem to only support a resolution of just 1280x1024 where as the screen has [SIZE=-1]1920x1200 so will look aweful. will using a vga connection lower the image quality or is standard tv/virgin box never going to be better then what a vga can do?
as the screen will be used at night as a tv i need a remote to turn off the device and also obviously change the channels and such.
im also wondering would a good freeview box do what i am after? in that i can plug virgin box/dvd player/wii etc up to it and then the box into the monitor and also give me a remote to switch between input and channels of freeview.
[/SIZE]
[/SIZE]
