- 27 Mar 2019
Hello OcUKers,
I currently own this machine:
MOBO: Gigabyte ab350-gaming 3
CPU: Ryzen 5 1600 (@3.8Ghz)
Cooler: Corsair h100i v2 (with 4 fans, 2 on front, 2 on back of radiator at the front of the tower)
GPU: MSI AMD RX480 Gaming X 8Gb
PSU: Corsair TX 550M (550W)
Requirement:
I have a few issues:
I was looking at the Sapphire Vega 56 Nitro+ Limited Edition (but it is a hugely long card).
So it would need to be:
Phil Broadey
Requirement:
- My monitor is a 144hz F-sync monitor at a resolution of 2560x1080 (I don't want to do 4k gaming - I want games on low settings running at >144fps)
- I want to try and stick with AMD if possible (as I usually support the underdog company).
- Would like to use F-sync but I do use RTSS S-Sync feature as a replacement to prevent tearing.
- My PSU has only two GPU power cables. 2x8 pin. So if I need anymore I would have to upgrade PSU or use a 8pin splitter to trick the GPU into thinking I have 3x8 pin.
- My PSU only has 550W (but I might be able to run a tuned Vega64?)
- My current GPU is 276mm long (and there is only about 15mm gap from my radiator fans).
- A clear upgrade
- Successfully powered by 550W
- Shorter that 290mm
- Not a reference card design
- Powered by ideally 2x8pin GPU cables.
Phil Broadey
