Struggling with logitechs absolutely horrendous software.
Man of Honour
13 Jul 2004
They really are apalling at writing software. Is there anyway I can intall their setpoint software for my keyboard only and use decent drivers for my mouse? I KNOW I used to have the option but those clever clogs saw fit to remove it. :rolleyes:
Cheers guys.
Had a bit of trouble with setipoint for my G7,had to dig out a old driver to get it to work :mad:
clone said:
247 works for me,i tryed the 330 one`s and had nothing but trouble with them.
330 and 310 were the ones I'm trying, I swear logitech have just hird a bunch of monkeys to code for them. Cheers mate.
Cheers guys.
[OT rant]
You think that's bad?
Well despite it being available for the best part of 6 months, and Logitech plastering stickers with "Ready for Vista" on the box, there are STILL no G15 drivers for Vista.
This is beyond a ******* joke now. :mad:
What they suggest is a bodge around using the XP/XP64 drivers, and in many cases this just leads to crashing and/or incompelete performance.
I thought Creative were bad, hell they're angels compared to this pile of rabble.
[/OT rant]
Im getting a G15 soon but it will be on xp as vista was nothing but trouble when i installed it. :(
They say on the Logitech forums that drivers are coming end of the month.
If there's nothing ready by 1st May then it's going on the MM.
I also use a Logitech keyboard and mouse and was thinking about buying a webcam from them as well,but due to the amount of software that tends to come with logitech and the uncertainty with Vista compatibility I went for a Microsoft cam which was Vista compatable.
So I put in the software disc and got "this software is not Vista compatible" message.So I had to follow a link and download a 100mb+ download to sort it out!!
Nice one Microsoft,could have had a Logitech and installed their over bloated software instead :rolleyes:
i had problems with my mouse - it kept reverting to a lower sensitivity when gaming and you couldnt turn it back up without tabbing out or quitting all together.
I turned off the 'apply game settings' option and its all good now:)
