My motherboard is a Crosshair V Forumla - super old I know but still works great.
I upgraded my computer water cooling and i now use a EK-XRES 140 Revo D5 RGB PWM.
Ek gave me an RGBW cable that looks like this -
Now as far as I am aware, I dont have any header on my motherboard to support RGB.
I took a look at Corsairs Lightning node Pro but I have been unable to find out if it works with non Corsair products. However the lightning node pro controls RGB cables that look like this
So my questions are
So my questions are
- Can my EK's RGB lighting strip work with the lightning node pro
- If yes, then what adapter do i need
- If no, then how can i make it work with my motherboard
- What is the diference between the two difference types of cable.
