It seems that my E2200 won't go above 2.8GHz.
I'm at the stock voltage of 1.325v and fsb is 1018MT/254.5MHz, and I'm using a divider of 7:11 to keep the ram at 800MT/s. Max temp is 48 degrees, prime 95 stable. But as soon as I increase the fsb to 1054MT/s the computer jams when loading windows or logging on, even if I put the voltage upto 1.5v! Surely the E2200 can do better than this? My motherboard is an Asus P5N-E.
At 3GHz now and counting.
