Stuck at Verifying DMI Pool Data for 8 mins
10 Nov 2008
Isle Of Wight, UK
Hi All.
I am looking for some help and advice with a problem that I am having with my whitebox server build.
As per the topic title, I am having an issue that the system will just sit at "Verifying DMI Pool Data ............." for 8 minutes, the hard drive LED is on continuously throughout this time, then it will continue to boot just fine.
The previous and current whitebox server is running ESXi 6.0 (VMware vSphere Hypervisor 6.0).
Current whitebox server
Gigabyte GA-X58A-UD7 (Rev 2.0) / Bios Version: FD (2012/11/09)
Intel Xeon X5570 Quad Core 2.93 GHz
24GB (6x4GB) PC3-10600 DDR3-1333 M393B5170GB0-CH9Q8
Matrox G550-LP-PCIE
HP Smart Array P410 Controller
Intel Gigabit VT Quad Port Server Adapter
64GB Crucial CT064M4SSD1
4TB Western Digital Red WD40EFRX
4TB Western Digital Purple WD40PURX
2TB Western Digital Green WD20EARS
Seasonic SS-620GB
Previous whitebox server
Gigabyte GA-P35-DS4 (Rev 1.0) / Bios Version: F14 (2009/06/19)
Intel Q6600 Core2 Quad Processor 2.40 GHz
4GB (2x2GB) PC2-6400 DDR2-800 Corsair CM2X2048-6400C5DHX
2GB (2x1GB) PC2-6400 DDR2-800 Kingston RMD2-800/1G
Matrox G550-LP-PCIE
Seasonic SS-620GB
I have been searching around the internet and it seems that some Gigabyte motherboards and ESXi do not play nicely together. But as of yet I have not been able to find a solution to the problem.
Does anyone have any ideas?
Thanks for your time.
Best Regards.
