Stuck between a rock and a hard place !!!!
18 Feb 2004
Location Location
Lo all,
Right here's the problem:
I have £400 to spend on either an HD TV/Monitor for my existing XP-M, DDR400 and X850 Pro rig and xbox 360, or do I upgrade my PC with the £400????
Dont game much on my PC since its too old, and I now have a 360, but do I upgrade to play new games or do I get a nice TV/monitor and use my 360 for the gaming
Help me decide guys.............
Thanks in advance
SMIFFY
Vote for the xbox here, you can play most new games out on the pc on the xbox too also you'll immediatly see the difference in the high def games.
Personally if you game on the xbox360 I'd say go with the new HDTV/monitor route ...
The PC you have at the moment should be fine for while yet for normal non-gaming use unless you are doing something particularly heavy with it, (e.g. photoshop), but playing games on the xbox would be a lot better on the bigger screen and you could, (assuming you got an LCD TV), hook it up to the PC as well as a second monitor.
