Hi
Need some help in choosing components please...
Usage:
Gaming, internet, office use, tv and dvd's.
Budget:
would probably aim to spend somewhere in the region of £500-700
Thoughts:
Noise: I would like a much quieter system than what I have now
Overclocking: Would like ability to do this - though nothing extreme required!
Timing: Don’t need to purchase ASAP, so can wait a month or so if worthwhile waiting for a bit of new tech
Got:
Case (Akasa Eclipse), Hard disk, Floppy disk, DVD, TV cards, keyboard, mouse.
Monitor - using old one for now (Though am aiming to get a nice Dell 24" at some point)
Operating system (xp pro)
Need:
CPU - undecided but contenders are 2140/60/80 (cheap end) - E8400 (mid end) - Q6600/Q9450 (upper end)
CPU cooler/fan/paste - Arctic Cooling Freezer 7 Pro (is a fan included?) with some artic silver 5 - is this ok for the above chips?
Motherboard - either a P35 or X38 - but which one to get? what are considered the best of each range (without being overly expensive)? what does the X38 have that makes it better than the P35?
Memory - would like 4gb, and to have no trouble if I overclock, so is 8000/8500 type ok? Which brand to get though? the gskill 4gb pack I have seen looks ok:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-022-GS&groupid=701&catid=8&subcat=817
Graphics card - some brand of 8800GTS - which is quiet? and are these ok to power a dell 24"?
PSU - corsair hx 620 - are they ok to power all the above and is it fairly quiet?
Thanks, Neill
Usage:
Budget:
Thoughts:
Got:
Need:
Thanks, Neill
anyway that is a decision for later...
