Stuck in Mass effect?
Caporegime
7 Apr 2008
Lorville - Hurston
Hi. i am currently stuck in this bit below:
spoilers.
13 - The Situation with the Colonists
At the weigh station Lizbeth gets out and is reunited with her mother.
Unfortunately, Jeong has gotten through to the ExoGeni corporate offices and
has learned that they want the entire colony purged to prevent the Thorian
from spreading. Using Charm or Intimidate you can talk Jeong out of it, but
otherwise you simply have to kill him. As for the colonists, Juliana Baynham
has an idea for stopping them without having to kill them. She offers you a
grenade upgrade which contains a nerve agent that should pacify the colonists
safely. Whether or not you choose to use it is left up to you.
She gets out of the meko and goes toards some lamp post and kneels down and thats it!
nothing happens. she doesnt get reunited with her mum as mentioned in the above quoute!
getting ****** off with this game lol.
here is the guide i got that quote from Mass Effect Walkthrough (Console) - IGN FAQs
Its the Feros mission.
Yes, she stays hidden until you move forward and trigger Jeong's sequence where he grabs Juliana from behind and threatens to kill her. Might be a bug if she doesn't scream and move forward when that happens.
cant get out either. pressing E to get out dont do nothing
I thought "Q" was the disembark button, and you need to be on a flat(ish) surface too. (Oops, beaten :o)
But you have to disembark, then walk down the ramp for the next crisis to kick off. Unless your 'bugged' of course, but I ain't experienced one in Mass Effect.
