Hey guys,
So I'm having an issue after attempting to format and clean install Windows 10 on my laptop. I have experience doing this in Win7 but not 10. I should have done some reading prior to giving this a go but hey, hindsight's 20-20 and all that...
So the steps I took were:
At this point the laptop boots straight into PXE mode and attempts to boot over ethernet. I can't access the bios to change boot priority because it seems to skip this step completely (tried pressing every key I can think of during boot). I think this is probably down to the fact that I brazenly ripped the HDD out of a system that wasn't fully shut down. Thanks windows 10.
I have now also tried removing the HDD again, installing windows on it through a separate system and replacing. No dice - still boots straight into the PXE "no bootable media" message.
Any advice on a fix for my stupidity would be greatly appreciated
Cheers!
Shut the laptop down (did not access advanced shutdown options or disable windows 10 fast startup, wasn't aware this was a thing)
Removed HDD
Connected HDD to separate PC
Formatted HDD as normal
Replaced HDD in laptop
Attempted to boot from USB to install windows 10
Cheers!
