gam3r said:I can't seem to pull out a molex connected to my 6800gt. It just refuses to come out even with force!
What should i do?
Psycho Sonny said:cut it using scissors then just wrap some insulating tape round the live wiring
fish99 said:This is why you should use the supplied molex extension thingy, if one came with the video card, and if one didn't come with the video card it's well worth buying one for a couple of quid, then you don't ever have to unplug the molex going into the board. If that socket ever falls off....![]()
All you can really try is easing it up and down as said earlier, and wiggling the wires around. It can take a lot of force when they get stuck though.
gam3r said:Finally got the git out, damn thing took me ages!
What should i do?
