stuck on overlord 2 need help
4 Jul 2009
Kilham, East Yorks
im embarrassed to say but i am stuck at the first lvl of overlord 2,it says follow the little girl but how???,i have tryed every thing i can think,please if you have this game and are further then me please tell me how too do it.
ps; i played the original overlord and never had this problem
i cant take 1 but its when i have to get in the town and it firsts says follow her if that helps?
Ah, turn around 180 degrees from the gate and you should see a barn on the right hand side, near where all the kids hid moments ago. You can go through that barn and on to the rest of the map.
Sorry for the delay, got a bit stuck in L4D.
I think this is the area you are on about.
Facing the closed gate:
Turning around to face the direction you have just come from:
Edit: Sorry, guess I should've resized them a wee bit... I'll do it in the moring.
I was sure this thread would be on the part that i'm stuck on.
On the boat level with the mermaids (I have browns and reds)
there's an island thing that I guess you have to put the things on, problem is I can't find the last one?
I can do another mission but I think I need the blue's from this mission to be able to get anywhere on it.
anyone?
anyone?
I know the bit you are at.... ram the pile of rocks! As you face the large gate, turn left and follow the shore on the right. You'll come to a large pile of rocks. Get upto ramming speed and blast through the rubble.
If you are really stuck then there are walkthroughs on youtuibe.
how do you get the man at the gate?
He should just appear there....
Have the kids barricaded themselves into their hideout place? Perhaps you haven't caused enough mayhem and destruction yet in which case
DESTROY EVERYTHING
well, everything that can be smashed at least.
If that doesn't work then try starting a new game, maybe you've encountered some form of bug.
DESTROY EVERYTHING
well ive tryed everything,ive smashed,burned evrything and killed all the bunneys to no luck the man still wont come too the gate it justs says to talk to the girl but i cant talk too her.i think i might have a bug,ill reinstall it and try again
it works fine now that ive done a reinstall,lol i made myself look stupid when in fact it was just a bad install
