Stuckon updates
14 Dec 2013
Morning all,
Normally I'm ok at sorting windows boot issues.
BUT, I'm stuck atm.
Did a scan and found some malware... av deleted it.
Laptop rebooted to finish the removal BUT, as the wife never restarts the laptop it went into installing updates aswell..
Annndddd the battery dies.
So it's currently having a complete arse around.
Will not boot into windows.
Have rewritten boot, file check, booted into hirens and can see that the drive is not full,
Not really wanting to full wipe, there are recovery sectors on the drive but can't access them
Tried to work out how to redo the windows install but it will not give me the "keep files" option.
Any ideas or help will be grateful..
It's an 8th gen msi laptop on windows 11.
Thanks in advance all
What malware AV found and deleted? Can you remembered the file location AV deleted? Could be false positive caused AV to deleted critical system file that caused unbootable to Windows?
Windows 11 supposed to rollback failed updates next time laptop is recharged battery and booted to Windows then download and install updates properly again.
What AV software you are using?
Morning all,
BUT, I'm stuck atm.
Boot into recovery
Open a command prompt
sfc /scannow
How did you rewrite boot file?
Bootrec commands?
And checkdisk or sfc /scannow?
This is why you should
Have image backups
Couple of minutes to restore an image
Compared to days of trying to fix something
To force it into recovery options
Turn it on
Turn back off by holding power button
Repeat a few times in a row
Though basically going to be mostly same recovery options
You would get by running windows install media
Though trying boot into safe mode
Would probably be the option i would go for
Will say completed and then on reboot gets to 3% configuring pc...
Sat there for 4 hours would not go past it..
Why is software such a pain ... thanks for the help it is appreciated..
Might have to offline dism the hell outta it.
It's pretty easy, and should fix your stuff.
