Studying for my theory
Permabanned
12 Sep 2005
England
Advice?
I have The offical DSA theory test (With the higway code at the back) book a cd with a mock theory test. A dvd with a mock theory hazard test and some other dvd. I borrowed them from a friend, they are all dated 2005, Has the syllabus changed much? Should I buy an updated kit?
That'll all be fine, the whole thing doesn't change much, I think they may update the clips, but I doubt it really. :)
Just run through them loads and you'll do well in the test. :)
InvG
if you have a look around (google) i found a site that had a few hazard tests on, because i found the CD's only had a few on. Once you have done the cd's once or twice you know the hazards so become useless.
