Basically, I need to record readings from an accelerometer and view it on my computer. I have found some cheap accelerometers that will be accurate enough, the problem I have is how to acquire the information from them.
To use them you put a voltage in one end, and it outputs another voltage at the other end, the stronger the voltage, the more G it is reading.
So now I need some sort of hardware kit that will allow me to record the readings from the accelerometer and save it onto a computer so I can work with it...
I have no idea what I need to buy, do you?
