stupid 45 degree fitting question
Caporegime
7 Apr 2008
Lorville - Hurston
Hi i just bought a pair of bspoke 45 degree 1/4 1/2 OD rotary fitting and quite miffed on how to attach the rad to the end of it.
At the end of the part where you connect a WC component on it, it turns and rotates endlessly without moving. i am trying to take that bit that turns so i can screw the whole end to a WC component but it just turns and turns and thats it?
what am i doing wrong?
Is there not a flat on the thread, or near the thread so you can get a spanner on it? Sometimes there is a hex in the bore to allow a hex key to fit in there instead (thoguh I have not seen these on water cooling before)
Might be able to budge it with a strap wrench, something like a Baby Boa Constrictor Strap Wrench.
Great thing to keep in your pc tool box.
If its knurled on the bottom just grip that part and turn, be warned though it can chew up your fingers real good :p
Or just get a pair of slip-joint pliers on it.
