When I fitted my cpu cooler I didn't bother reading any instructions regarding applying the cooling compound and so applied much too much. I scraped some off but Im not convinced that it has done the trick really. Probably still too much on there and I have read about bubbles in it causing problems if you dont put it all in a single blob in the middle (I didnt
Do you guys think I need to be worried? My temps seem to be okay but I don't want them any higher than they have to be.
I bought some replacement compound of a certain auction site for £1. Is there much difference in the quality of expensive vs cheap? Am I better off with badly applied good compound or well applied cheap compound?
Any help would be amazing.
Thanks
)Do you guys think I need to be worried? My temps seem to be okay but I don't want them any higher than they have to be.
Thanks
