Ok, so just driven to the local village to get some lunch. On the way there I had to perform an emergency stop from 60mph (probably a bit higher). The brakes worked fine, as expected and I managed to drive off fine after that. The next time I used the brakes, a mile or so further on I noticed that the front right brake feels different.
It's almost like the disc is bent, it's causing the corner to vibrate heavily, which changes frequency depending on speed. Braking is now biased to the left, although the right isn't really much worse in terms of braking effort. The pedal bounces a bit too like the piston in the calliper is being smashed in every turn of the disc.
It sounds pretty rough too.
When the brakes are off, the car is as normal.
Car in question is a 2001 ford focus 1.6 petrol with 135k on the clock.
Thoughts?
Thoughts?
