Stupid me :(
24 Dec 2011
Gone and tried to get abit of dust off my mirror in my camera and touched the focus lens for my viewfinder :( Cannot for the life of me clean it.
Anyone recommend any good shops who can in the area of yorkshire or humberside?
Its a 400d eos, Im a wally so will have to pay to get it sorted as its gone messed up :(
I've changed the viewfinder in my 5Dii, worse comes to worst, you can replace it easy enough.
It is a pain to clean though as it is not a flat and smooth surface, it has tiny tiny ridges.
Yep noticed cleaning is out the window as running a cotton bud revealed its ridged.
Is it a hard job Raymond i was thinking of letting a shop do it to be fair as then i also have a warranty for such is all. Iv found the part online 3 days shipping to me for 11 pounds its just having a steady enough hand to fit it without damaging it or getting more dust into the camera
It's quite easy to do, it comes with a little tool to do it in. just clips on and clips down.
Just take your time. :)
Mind you if the worst comes to the worse and you manage to totally destroy the camera you can get another on ebay for only £100 :p
Then cleaning the mirror? Cos thats also bit messy now :') Any ways to do this or any tools to help?
Oh dear, what are you doing !?
Don't touch the mirror, it is actually more delicate than the sensor (which is behind a piece of glass). The mirror on its surface is unprotected, and it's advice not do touch it or clean beyond a blower.
The general advice is if it does not affect focusing, leave it alone.
Making a real mess, its going off to canon :') 36 quid for one of there service centers to sort it out for me and replace the part along with cleaning mirror and sensor
That will work i guess
