Stupid me
28 Nov 2020
I have an old laptop with vista on but wanted to change to windows 7 so could add my golf SIM, went onto you tube and one guy said split your c drive into two then make the new one active so I did this, then when I restarted it comes up bootmgr missing, I presume it's trying to boot from the one I split and made active, I'm not good with these things, sorry for the long post.
Steve
It's not clear if you actually performed a windows install or whether you wiped the drive before partitioning (presumably what you mean by split).
If all you need is to get the system to boot from a different partition, you only need to go into the bios and change the boot priority/order. No idea what key you press for the bios on the laptop, but there's usually some information on screen that details what key provides bios access (it'll be at the bottom literally right at the start). If not, it's probably a google away if you could specify what the laptop is.
***MOST IMPORTANT!!!***
Have no idea if youtube guy has advised you but what youre doing is pretty risky, do you have ANY important data on the laptop, pictures etc that arent backed up? If yes, you might wanna take the HDD out first and back it up on a pc using a sata-usb adapter.
t31 has covered this, but presuming you made a new partition, formatted that whilst in windows, made it primary (you changed the boot order?) then restarted yeah could cause issues, cos its trying to boot to hdd with nothing as far as windows is concerned.
you should be able to install windows to the new partition though, bootmgr missing shoudnt come up if youre trying to install windows??? so not sure what youve done with the partition. New partition was made in windows? Tell us how. or link vid would be handy
When you install windows 7 it will obviously ask what partition youd like to install on, so choose new one.
Failing that,as t31 said you should be able to change boot order from the bios.
youll need to change the boot order anyway to boot from windows cd or a usb flash drive with windows on anyway (to install it). didnt your youtube guide cover this? OR have you clicked to install windows from within windows itself?
Before we overcomplicate this, do you have anything important you need to retrieve from the laptop?
If no, it's easy from here.
Do you have Windows(the installation software) on a DVD or USB (flash drive)? Do you know how to get into the bios on the laptop?
Yes that's probably the bios, but I can't see how you were expecting to install windows without a copy of windows.
Without using a disk, not without having a copy of Windows. Part of the process in that video (not that i'd ever personally ever install windows this way) is extracting the windows ISO (image file).
You can certainly find ISO images of Windows on the web (MS themselves use to provide them), but that won't necessarily provide you with a valid license and product key.
You can technically buy them as cheap as £10 (i'm not providing any pointers in that regard), but it's a very grey area as to how valid they are (although they technically often work and activate).
I can't mention competitors(forum rules), take a look on some secondhand marketplaces for an OEM license for Win 7.
For the interim, if you want the laptop useable(for browsing or whatever), there's always free operating systems like Ubuntu (won't likely support your game, but you can at least use it for web browsing).
