- 15 Nov 2007
i have a jeantech 1000w absolute psu and as you probably know allready its modular,ive just installed my two 8800gt's and have them connected via the 2 leads theat come with the cards (6pin conector in the card splitting into 2 normal conectors).Now my psu has 4 pci-e slots on the back and i have the leads,there 6 pin leads the same but the wiring is differant,the lead that come with the card has yellow and black in the first 2 pins,2 brown in the same pin in the middle and again yellow and black in the 3rd set of pins if that makes sence,the ones with the psu have wires to all 6 pins as appose to 5,can i stiil use them?the lead from my old 8800gts is the same as the gt,s so it aint just them....thanks guys
