- 7 Sep 2007
No Problem found out it was my q6600 with silly temps was causing the problem.
Coretemp is innacurate, your better taking readings from Bios.
ok i lapped my cpu ages ago and on my previous boards all cores have been close to each other give or take 2c which is normal so I have never ever had the temp problem only since putting it on this board.
I have stripped it like 6-7 times checking everything over and over again and still getting the same results. At first I thought it was my water block so I placed the normal intel heatsink fan on and still the same core 0 was 20c hotter than the other 3 cores?
unfortunate seeing as lapping it just invalidated your warranty.
There's no way they can tell that you have clocked it, however a shiny copper IHS kinda gives it away that you've lapped it.
