Hi,
In the middle of a new PC build. Installing a Corsair Nautilus AIO cooler. The MB is an Asus TUF B850 plus WiFi.
Slightly confused about which MB headers to use. The cooler has one power lead for the pump and a separate one for the fans (the fans are not connected electrically to the cooler at all).
MB manual says to connect the pump to the AIO_PUMP header and the radiator to the CPU_FAN. However, the cooler manual says to connect the pump to the CPU_FAN header and the radiator fans to another fan header on the MB.
Clearly I can’t do both. So which do I do?
Option 1: MB manual (pump to AIO_PUMP, fans to CPU_FAN)
Option 2: AIO manual (pump to CPU_FAN, fans to another fan header, nothing to AIO_PUMP)
