Stupid question but better to be safe than sorry.
16 Jun 2011
Hey all im buying a Lian-Li PC-7FNWX case which has a what looks like removable panel for a 140mm fan, but what i was wondering is will any 140mm fan fit in perfectly or even a smaller one? I was looking at buying Xigmatek CLF-F1453 Green LED version (Need green LED) any other suggestions?
Also Im getting the thermalright silver arrow which way should I have it? More verticle so it does not cover the ram or horizontal so it does slightly?
Thanks everyone :D
The removable cover should fit any 140mm fan, but you would need an adaptor to fit anything smaller (unless stated otherwise, the fan size refers to distance between the mounting holes).
Depending on your board and RAM, you may find that the silver arrow won't fit with both fans attached while oriented horizontally - if it will, though, that would probably be the better option (no obstruction due to GPU).
