Hey all,
I currently have on order from OC, two of these.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-362-EK&groupid=962&catid=2133&subcat=1845
But the issue is they've been on pre-order for about 2 weeks and im getting impatient.
Could I achieve the same result by upgrading the pump to the EK 4.0
http://www.overclockers.co.uk/showproduct.php?prodid=WC-104-EK&groupid=962&catid=2141
and then use the EK X3 Multioption res
http://www.overclockers.co.uk/showproduct.php?prodid=WC-312-EK&groupid=962&catid=2133&subcat=2135
Would this basically achieve the same result as the original item I wanted, but of course using a 400lph pump instead?
its probably a stupid question, but I like the compactness of the original item I ordered and want the other set to look essentially the same and require no extra tubing/fittings.
Cheers
Chris
Cheers
Chris
