Stupid question re: two GPUs
27 Dec 2005
Bristol
I've got two GPUs in my home PC, a GTX 1050 and a 1080.
Only reason being is I bought the 1080 but needed more HDMI ports for the Oculus Rift and had a spare 1050 at work.
Is there any advantage to having two (besides the use of the Rift), and if so do I need to do anything to make them work together?
I do not see how you can use them both with Rift. The 1080 alone should be used.
You can’t run them sli so it’s pointless having the 2. I mean unless you use the second card just to power a separate tv for other viewers. If that’s even possible
You can run non-gaming monitors off the 1050 ti, but your Rift and gaming monitors should run off the better GPU.
you are doing it wrong.
your monitor and rift should be run off the 1080.
your 1050 should only be used for watching movies on a tv, etc.
Lolwut. The only idiot is the one who can't explain things clearly. It's why others also pointed out the exact same thing.
Also any smart person would know you can't combine the power of two different gpu together.
I think he's referring to people watching him flail around like an idiot in VR rather than people on the forum.
