Stupid question what are these called?
17 Jul 2008
London
One of the little plastic things that help to keep a keyboard on an angle went missing and I can't find it anywhere, so what are these things called and where can I actually buy it? Searching for "plastic keyboard support thingy" is not helping xD
Cheers!
Edit: I wanna be a hippy and "recycle" instead of buying another keyboard for £3... Since its new and all...
You will not be able to buy them separate to the keyboard, manufacturer specific I am afraid. Just blu tack / glue gun / araldite a replacement, maybe a few pennies etc.
:D
i recommend big blobs of blue tack. mold to correct angle/height. did it for my dad and he says it works fine. The other benefit is the keyboard doesn't move around the desk :D (might be an advantage or disadvantage...)
