- 17 Mar 2004
So I've had my car nearly a year and from a month after picking up my Civic the brake pedal had a slight squeak worse some day than others, non existent in the rain. Roll on yesterday was driving up to London from Dorset in the afternoon. Having just had 4 new tyres fitted driving home I arrived on my drive and thought I would tackle this once and for all. Pushed the seat back and had a nosy under the pedals. I had previously dismissed the noise for an issue on the drivers front caliper hence no noise when it rained must have lubricated the squeak. But obviously with the engine on (diesel) too noisy to check with the engine off the pedal would lock up after a few depresses. Anyhow....yesterday with the seat rolled back the noise would be there wiggling the pedal slightly and audible inside the car. I then thought maybe master cylinder but kept on fiddling cutting hands to pieces in the interim. Then I noticed a push switch in front of the pedal hidden by the dash shroud. Eureka pushing this was making a slight sound so I started with the disassembly and loaded the spring with wd40. Replaced the shroud that extended under whole steering area and side so the door had to be opened. Clip it back thump the clips back in place etc. Key in, press starter button.....Check ABS, Check VSA, Check Airbag, EML. ********. Thought the worse had I shorted out and broke the switch with the WD40??? Took it all apart disconnected switch tried again same thing. Starting to panic three hours till I have to go to London wife anxious etc. Call AA, will be 40 minutes. Whilst I was waiting I tried disconnecting battery and leaving till everything reset. Same thing. Went online and thankfully seems quite a common occurrence when people fit hands free and the like. Fuel cut off switch had deployed. Drivers side from when I was replacing shroud thumping it in place. Yep pushed the button all was fixed.
What a morning!!!!!
Anyone else had similar experiences of home Car DIY gone wrong?
What a morning!!!!!
