Stutter , fps drop all games ?
12 Jun 2007
Ireland
Stutter , fps drop all games , black screen ?
Hi hopefully someone can help me as it driving me mad ,
only started happening 3 weeks ago ,
i noticed while playing csgo that fps would drop down for a millisecond to and game would have a freezing effect / freeze for a millisecond , like a stutter happening once or so every minute.
then i tried different games and it is happening to .
i tried reinstating drivers installing older drivers updating sound drivers , taking the gpu out and plugin it back again, and it is still the same .
games are on the hardrive , c300 only has the drivers and os , ram stock settings xmp so should not be a problem, i think
edit: tried gpu at stock same thing
mostly csgo and tf2 , even game osmos had it , i'll try suggested after work and see if other games have the same issue.
run any tests for the c300? and/or the 1tb?
any smart warning/errors? I dunno why its stuttering like that
ssd above hdd bellow is it fine ?
EDIT: os drive wasn't reformatted for a year or more so it is bit slower
also started to get getting black screen randomly when gaming , just goes black and then boots back to windows retarts .
anyone any idea
well it is not a memory its all fine i did defraged couple of times , i think it is ether software related or gpu related.
i have somewhere spare 4870 1 gig i will test it , and i also ordered Samsung 840 evo 120gig for os drive will reinstall windows when i get it.
might get 500 gig for games later on firstly need to solve the issue.
edit: when screen goes black says " no dvi signal"
well i fixed the issue it was something with connection or not plunged in right and it disappeared so strange , i plugged everything out took ram gpu out plugged everything back in and the wires and it is fine now.
issues returned when i put 770 back again seems to be gpu related , with 4870 its fine with 770 its a mess, rma time ?
I had this problem twice, first time my fans on my GPU had given out and it was over heating, second time the temp on my CPU was getting too high and had to use some new thermal past. Try Core Temp and MSI afterburner to monitor the temps.
heat should not be the problem its happenings even when playing tf2 or , csgo cpu max reached temp was 52 , gpu was 50 c .
