Hi all,
I am in need of some help with a problem I've had for over 12 months ever since I built my computer.
It was built for the sole purpose of running flight simulator X
These are my specs,
Gigabyte GA-EX58-UD5 Motherboard.
Intel core i7 920 D0 Stepping CPU
Corsair 6gb (3x2gb) 2,000MHz Memory
Cooler Master V10 Hybrid TEC Cooler
2 x Western Digital Velociraptor 150GB 10,000rpm Hard Drive and 1x 300GB Western Digital Velociraptor
Asus ENGTX285
CoolerMaster Real Power 1250w Power Supply
Now as far as I can see this should kick some ass as far as FSX is concerned "WRONG" It is absolute CRAP, I get Stutters, Spiking and total freeze ups.
I am convinced it is hardware related as I know I have the flight sim set up properly, it is worse when I have the autogen on so I do leave this off but it still stutters and freezes the only thing the autogen helps with is the spiking.
I thought I had found the problem a few weeks ago when I sent my CPU and MEMORY back to where I bought it from for testing and it was found that the memory was faulty when being used under heavy load, great I thought that's it problem solved, so when the replacement arrived I could not Waite to get it back in and fired up but low and behold it was exactly the same ( the CPU tested O,K by the way )
So can some one please point me in the right direction and give me some idea where I should be looking I mean this computer has cost me some serious money to build and I've got to say it's almost unusable.
Thanks and kind regards Kevin.
These are my specs,
Asus ENGTX285
