Sub £200 Ergonomic Chairs
Recently bought the M57 Sihoo
I am am under 6' 1" and the headrest, even at maximum height, is too low. The lumbar support is also too low.
Have seen other reviews stating the same issue.
The chair itself: even when locking the tilt mechanism in place there is still movement (and noise). That will continue to worsen over time.
For £50-75 I would bin the headrest and put up with the rest. For £170 it is going back.
Must have got a faulty one maybe. I got mine for £130 delivered and it’s great.
Im 6’ 2” and was able to adjust the lumbar support to suit me. I don’t really use the headrest but it seems high enough?
That said I'm using it to WFH and not for gaming if that makes a difference.
For the money it beats all the other catalogue shop chairs i’ve had over the years :D
Chairs are like mice and personal preference comes into play.
I also have the M57 and it's one of the better chairs I've owned, much better than any gimmick gaming one before it.
No faults. The adjustments all move as they should.
The headrest isn't too far short but enough that it is uncomfortable and quickly becomes painful. I tried removing it which was better. Sadly the lumbar support is a lump of plastic with what feels like 2mm of padding that pushes too low in the back. Have seen others post with identical problems some even going as far as removing it from the chair. Also my wife found the lumbar support far too uncomfortable (I tried giving her the chair!)
As long as you buy from a place with easy returns you are good.
It will either fit or it won't. Same as any chair you buy.
Got my M57 today and my initial impression are that I'm probably going to send it back.
The seat bit is uncomfortable, the backrest is uncomfortable, I dislike the tilt mechanism and I don't think the gas thing goes quite high enough (which I should probably have checked but to be fair I'm not that tall so didn't expect it to be an issue). Also not a fan of the wheels, trying to move the chair is a bit like trying to steer a shopping trolley.
Headrest height seems fine though.
You are not getting the same level of comfort as a padded fabric chair for sure, but more durable and should last longer with the mesh.
I did have to mess about with the lumbar support to get it right as it was awful to begin with and needed adjusting.
For £130 delivered I am really pleased, but maybe I am just easy to please :D
i am in the process of getting a new chair. i have a gaming one now, a TX3 which is ok, but the missus is stealing it. is the M57 or M102C a good choice and they both look the same. i like thick comfy material seats. there are so many in this price point, up to £200 (i got the TX3 for £150 in the clearance deal) on amazon etc and they all have the same features.
Now sitting on a Orangebox Spira Plus Highback chair with headrest and happy as Larry after looking at getting a replacement chair for ages.
It was bit of a holy grail deal as I got it for £100 (from a well known used marketplace, seller made a mistake in the description and thought it was an Orangebox Do chair and priced it accordingly). Only 6 months old as well and looks practically brand new. I'm quite light so i'll probably get best part of a decade's use as these chairs are heavy duty and built like a tank.
If you have the patience; it's worth looking daily at the used marketplaces as eventually, really decent chairs from reputable brands pop up for reasonable prices.
