Sub £200 Photo Printer than can print NFC/ID Cards??
15 Oct 2007
Bedfordshire, UK.
So I am wanting to print artwork directly on to NFC cards and am after a printer than is able to do this.
I have seen some older printers used to come with a tray that you could insert id cards into and then insert this into the printer but models from HP, Epson or Canon dont see to offer this tray with their latest models!!?
I have seen suggests that with Printer that that have a rear paper feed and are able to print on thick card can be used to print onto NFC inkjet NFC cards but im not sure how wise this is and if it could damage the printer in the long the long term??
I was looking at the Epson XP-8700 which is a photo printer that apparent has, 'Rear specialty media feed and Thick Media Support, it stated to be able to print of media up to 1.5mm thick and if im not mistake most NFC cards are around 0.75mm thick.
Are there Printers for under £200 that can support printing on NFC cards??
