Sub £400 Build (- GFX Card)
17 Feb 2011
Heys Guys,
I'm after a build for -£400. Don't need GFX card as my MSI HD 5850 Twin Frozr will be going in it.
Intel
  • Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail
    £89.99
  • Asus P8H67-M Pro Intel H67 (Socket 1155) DDR3 MicroATX Motherboard - (Sandybridge) ** B3 REVISION **
    £89.98
  • OCZ StealthXStream 2 700W Power Supply
    £60.98
  • Antec 300 Three Hundred Ultimate Gaming Case - Black
    £47.99
  • G.Skill RipJawsX 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-4GBXL)
    £39.98
  • Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX)
    £29.99
  • Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366)
    £23.99
Total - £397.90
AMD
  • AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail
    £98.39
  • Gigabyte GA-870A-UD3 AMD 870 (Socket AM3) DDR3 Motherboard
    £81.98
    £60.98
    £47.99
    £39.98
    £29.99
    £23.99
Total - £383.30
Can I do any better? The cheaper the better, but the best bang for buck.
It's main use is gaming, a tiny bit of Photoshop and some web browsing. But that's pretty much it. Any processor will be overclocked.
Could I get a cheaper case? Cheaper RAM without sacrificing too much 'power'?
I'm after any ideas possible as i'm hopefully buying this weekend.
Thanks for your time,
Rob
if ya could i would recormend getting the 2500k and a p67 mobo if you could get the extracash for that, otherwise theirs nothing you could to improve much more
More than enough :), unless your going to run a high end gpu like the 580.
I run my system in my sig with 2 5850 gpu's and this pulled 430w from the mains full load and 500w with the 580, 615w with the 480.
Thats correct, the only ones you can really overclock is the K series chips on the 2500k & 2600k.
If you want to overclock the Intel one you'll need a P67, not an H67 based board. You can't up the BCLK, only way to overclock is through multiplier - and you'll only be able to go up 4 bins with a non K chip. So either a 2500k or 2600k will really be needed for a serious overclock.
Do you not have an existing case and hard drive you can re-use (at least temporarily)?
