sub £400 system spec
5 Oct 2003
Hello,
I am about to purchase the following kit (currently have 3ghz p4 northwood / abit max3 / 1gb pc4000 / 6800GT)
MSI K9N NeoF nforce 550 (AM2) DDR2 motherboard
Corsair 2gb DDR2 PC5300C5 (2x1gb)
AMD 64 X2 Dual core 5000+ 2.6ghz AM2
BFG 8600GT
Antec Sonata III case.
~£360.43
I need the system to run supreme commander, oblivion, & GTR2. In the future I would like to run starcraft II Unreal 3 and maybe crysis. I would be prepared to upgrade the graphics card in a year to run the new games.
Any opinions?
Thanks for any assistance.
what with the 4 new threads in five minutes! :confused:
Edit: Core 2 duo best way to like Paulus said, also they overclock far better
than AMD.
Rob
assuming the quad posting was a mistake ..........
intel core2duo probablly a better bet at the moment than an AMD....
The forums were going really slow, perhaps he clicked "submit thread" several times.
Go for Core 2 Duo, it's a much better option:
Do you have a PSU?
Do you have a PSU?
Thank you for your help.
I have an enermax 450W PSU. Would I need to upgrade to £500W for the 8800 card?
Nah, 450W is plenty. :)
You may also want to invest in a better CPU cooler.
A Noctua would keep the chip nice and cool at 3GHz if you were to overclock (which you should) and also be silent. :)
Do you have a PSU?
Thanks very much for your replies. I will be ordering this setup when I get paid next week. Would it be worth dropping the extra £20 on the P35C_DS3R motherboard for Penryn, or would that only be a marginal speed increase compared to waiting for the Bloomfield chipsets in 2008? I understand this is all crystal ball "who knows".
I've no idea, sorry.
Personally I wouldn't bother with the P35, but that's because I always upgrade everything at once, every 2 or 3 years. :)
Thanks all. That's the same time scale I have been upgrading. I will go with the original spec and upgrade when another step change occurs in the technology.
Thanks for the warning on the P35.
