Sub £50 freeview card recommendation
3 Aug 2004
Birmingham
Hi all,
Looking to buy a freeview tv card for under £50 from OCUK, what would you recommend? Only looking to use it for watching TV on my PC in my room and maybe record a program or two. Any recommendations?
Thanks
Russ
Leadtek Winfast DTV1000-T Digital TV Tuner Card
Or if you need analogue as well, get the other one.
Ok cool thanks, will take a look at the reviews and stuff first but probably get it. Seems to do all I want :)
