Looking to add a sub to my system around a £400 or so budget, currently only got the 5 speakers. 4 Tannoy XT8F floor standers as front and read and the Tannoy XTC as centre.
Room is 7 meters x 5.5 meters (though this measurement tapers down to around 3.5m at one spot). Listening spot is in middle though so pretty much centre distance between front and rear speakers. Main use will be for gaming and movies. Don't do much critical listening so believe ported will work fine here? Happy to be corrected and open to any other suggestions.
Have seen a couple of sub's, namely BK's range, in form of the Double Gem and XLS400 which come in around the price point, I believe the XLS is the better option from a chat with BK as while Double Gem has more cone area, the XLS400 driver apparently is capable of moving back and forth twice the distance so able to displace more air overall. Also looked at XTZ's subwoofer range which seem pretty solid and get pretty rave reviews. I am however happy to get any further input in solid options on the market I may have missed.
Have a budget up to around £400. Want the sub to be available in a white finish also! Appreciate there may be better options, but not after spending thousands right now as I expect it will be a placeholder of sorts anyways.
Thanks![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Thanks
