Sub Question
Si.
Si.
22 Oct 2002
Melbourne, Aus
Silly N00b question..
I've been replacing my crappy free Panasonic AV Amp with an older but better one but I'm not sure how to connect the Sub.
The amp has a single connection on the back (looks like a standard round audio connector) however the Sub has just the 2 wired as per a normal speaker. Do I need an adaptor to connect the 2?
Si.
Sounds like you have a passive sub, which needs the amp to beef up the signle so it will work. Most AV amps have the output that you describe which is a line level output designed to feed an active sub (one that has an amp built in) if thats the case your pretty much left with a decision bettween buying a new powered sub or a dedicated amp to run the one you have.
could probably give you a deinitive answer if you let usknow the Panasonic model numbers.
