Subnet spanning question
28 Sep 2008
Britain
So we have a VPN which operates in forced tunnel mode. This is fine, but if my users head off to a hotel, coffee shop, etc, and they operate on a 10.x address space, our VPN won't dial (although the machine will connect to the hosts network).
I'd like to find a way around this, perhaps a dual dial VPN that gives the user an option of VPN headend to dial out on, but ideally I want the VPN to be automatic with little or no user interaction....
Depends on the VPN, the IP range used by the third party network shouldn't matter, but I gusss in this case it overlaps with your corporate range. I've been experimenting with AnyConnect and forced tunnel config and it does it by DNS reachability as opposed to the IP range. Do you have that ability on your headend config?
