- 25 Nov 2011
- The KOP
Is it normal for an active subwoofer to hum when the receiver is switched off? The hum will stop once the sub enters sleep or I power back on the receiver?
With respect, they were reviewing a £5 cable, so it's not like the bar was set very high.It was highly reviewed on the rainforest..
I can't comment on that specific Maplin cable, however the general point is that with the vast majority of these cables there's insufficient information on the seller's web sites to make a proper informed choice. They give you vague descriptions and pointless marketing hype...Surely it be better than maplin special? I only paid £5.50
...but says nothing about what these technologies are, or how they work, or the benefits of them.The Maplin Range – Premium construction and specification, with marketing leading cable technologies.
Which is why I gave him a set of tests to do.I'm struggling to understand how it could be a shielding problem on the RCA cable if the sub doesn't hum with the receiver on. Surely that implies the source of the hum is coming from/via the receiver?
In fact, it's common to find there's no information on the impedance of the cable, what the capacitance value is, how much signal loss there is (dB/100m) and at what frequency. You're buying blind on the electrical performance specs. Similarly, there's nothing substantive about the construction e.g. shielding can range from foil only (completely ineffective at audio frequencies) to plain spiral wrap to foil and braid to double braid (the most effective). Along with that is what percentage of the cable is covered by the shielding. A sparse braid shield covering 30% of the cable is far less effective than two overlapping braided shields each providing 90%+ coverage; yet all could be accurately described as "shielded".
There are three reasons why high density overlapping braided shields are effective:
1) they provide near total shield coverage even when the cable is bent
2) foil shields work at gigahertz frequencies (radio/TV/satellite) but you need braided shields to work at the kilohertz range used for analogue audio
3) the shield is the 'path to earth' for interference. Foil shields are poor because of high resistance. Braided shields have lower resistance. The higher the braid coverage (%) then the better it is as a conductor to earth which makes it a more effective shield
Your Fisual cable is £5.50 including P&P and Amazon's fees to the seller. We can presume that the seller still makes a profit after paying for the stock and the staff to process orders. So think about it, how much do you really think that cable is actually worth?
If the Fisual works for you then great, but it's more by good luck than planning.
